My engine only has 3000 mile on it. Did leak down test and it was between 5 -2 % leak down on cold motor with forged pistons. Have the engine back in and hooked up. Just have to install my howe radiator and oil preluber and some minor things. I have the fuel lines done -6 and - 8 steel braid. Parallel feed modifed fuel rails. New RPS pressure plate and six puck sintered bronze from Mueller. Running the stock single pump till next week . I have to drive it to the fabricator to do the dual walbro fuel pump upgrade. I will dyno tune again up to 25psi on my stillen intercoolers. I am expecting my UAS FMIC and should be good for at least 2 bar. Mike
Arizona'a most powerful 600HP 15 second Z More powerful than a stock TT , slower than an NA Dynoed 515 rwhp and 420 ft.lbs @ 16psi 89 degrees. 533 rwhp and 450 ft. lbs @19 psi and slipping clutch and heat soaked motor , 85 degrees.
